94 elantra starter removal
Old Jul 28, 2007 | 02:46 PM
robnatl's Avatar
Default 94 elantra starter removal
need to replace starter on 94 elantra; where is it located? is there any site that has engine diagrams to show its location?
Old Jul 28, 2007 | 03:54 PM
zierk0310's Avatar
Default RE: 94 elantra starter removal
Try Autozone.com under their repair Info section.
Old Jul 31, 2007 | 08:25 AM
mechanic98's Avatar
It will be located on the side of the engine, where it meets up with the transmission. I think that one is located on the back of the engine, might be easier to get to from underneath. The starter will actually connect up to the flywheel, which is uses to turn the motor. Look around near the transmisson. Take a look at the starter, and see what it looks like, then look at your vehicle and try to see where it is... Get a haynes manual, or even a chilton manual. Don't forget to disconnect the Negative battery cable... if you don't... you will probalby see sparks... lol
zainecurtis
Apr 5, 2013 02:34 AM
7474
Mar 25, 2011 10:13 AM
Gaurav
Sep 14, 2005 12:44 AM
pure performance
Jun 6, 2005 03:52 AM
wink
Dec 3, 2004 03:06 PM
