Blinkers not working-2003 Elantra
Old May 11, 2008 | 05:21 PM
ToriL's Avatar
Default Blinkers not working-2003 Elantra
Within the past two weeks I had the flasher/relay for the turn signals replaced. It is again not working, and is making a crackling type of noise when you try to use them. I had assumed that when the relay was changed that this problem had been corrected. Has anyone else had an issue with the turn signal relay in a 2003? I'm thinking that it might be shorting out, but am getting frustrated with the thought of taking it back to have the part replaced AGAIN.
Old May 12, 2008 | 07:39 AM
kartoos's Avatar
Default RE: Blinkers not working-2003 Elantra
Check if any of the bulbs are not blown off. Usually, if one of the bulbs for bilnkers is not working, I have seen this happening. As simple as changing the bulb may solve it.
Old May 14, 2008 | 07:08 PM
madindian1's Avatar
where are you buying these relays from? and when you replaced it did it work fine afterwards? if that's the case you need to have them replace the faulty part.
lausterboy
Apr 20, 2012 03:02 PM
anita
Apr 27, 2009 07:18 AM
lovemybump
Jan 11, 2009 09:19 AM
jnartker
Dec 21, 2008 09:25 PM
Chuckprev
Jan 11, 2008 04:42 PM
