Brake Light LED Bulbs
Hello,
Just had a Brake Light go out and was thinking to possibly change over to 2357 LED lights
I see there are 2357 White and 2357 Red listed on some Auto Parts Websites for a 2011 Hyundai Elantra GLS sedan.
Like you could use either one. The original 2357 Bulb is Clear.
Not sure which to go with . Has Anyone changed over to the White or Red?
Which one would be the best to do?
Any thoughts?
Thank you
Any thoughts?
Thank you
Wanted to Try New LED Bulbs instead of Old Clear Glass Type Bulbs.
They make them in LED White or Red light ( auto parts stores called out both would work).
so looking for if someone had experience with them for brightness.
Was thinking maybe the red would not be as bright
Thanks
Thanks
Hi, there
It sounds like you are considering changing your brake light bulbs to LED lights. There are a few things to keep in mind when making this decision.
First, it is important to make sure that the LED lights you select are compatible with your car model. The 2357 White and Red LED lights should be compatible with a 2011 Hyundai Elantra GLS sedan.
Second, you need to decide what color you want the LED lights to be. The original 2357 bulb is clear, but you could choose to go with white or red. It is up to personal preference which color looks best.
Finally, you should consider what effect you want the LED lights to have. Some people prefer the brighter look of LED lights, while others like the fact that they use less energy than traditional bulbs.
