A/C, heat & fan only work on temp setting #1
I was told I needed to replace my blower motor resistor at my local part store. I changed out the resistor and that does not fix the problem. I have already checked fuses. Looking for suggestions on what this might be. It's a 2006 Hyundai Elantra. Thanks in advance.
Temp setting 1 or fan blower speed 1? The Temp dial and the fan speed dial are two different things. It's possible the dial itself is bad.
1 Attachment(s)
It is the blower fan speed dial, when I turn it past one, the air stops working.
My Tucson had the same problems many years ago. The fix was to replace the dial assembly.
