Corrosion on Cylinder 1 coil output!
Old Jan 3, 2008 | 06:21 PM
AManiscalco2007's Avatar
Default Corrosion on Cylinder 1 coil output!
I checked the coil thorougly and 2, 3 and 4 on the coil output were the plugwire connects were clean. However, the #1 was corroded. Any Ideas?
Old Jan 3, 2008 | 10:33 PM
madindian1's Avatar
Default RE: Corrosion on Cylinder 1 coil output!
i would just clean it, try to install some di-electric grease to prevent the corrosion next time.
Old Jan 5, 2008 | 07:28 AM
I did do that and I also cleaned the entire coil pack because, it had oil residual all over it from the valve covers leaking. I am just gonna go ahead and replace it because, it still ran rough after. I am actually just gonna buy everything new, to be safe. What brand do you recommend?
Old Jan 5, 2008 | 04:21 PM
madindian1's Avatar
remember try dealer parts especially plug wires.
Old Jan 6, 2008 | 07:07 AM
Yes, i'll do just that. Thanks again.
charliebird333
Mar 30, 2010 08:51 AM
jmasilunas
Jul 21, 2009 11:24 AM
speeder
Mar 9, 2008 07:05 PM
Stacey98Tib
Sep 30, 2006 08:41 PM
BobMcLean
Dec 18, 2005 03:52 PM
