Driver side master power window switch
Old Dec 17, 2023 | 02:21 PM
Jcthelight1976's Avatar
Default Driver side master power window switch
Hi I have a 2020 Hyundai Elantra Special Value Edition and my driver side window switch went bad and I just want to know if you got to remove the door panel to replace the switch or does the switch just pop out of the console and does anyone have any videos on how to do it
Old Dec 18, 2023 | 10:15 AM
If the master sw is on the driver's side door, most times the sw assy can be carefully lifted up and pulled out to replace or do some checking.
If you don't have the finesse and patience for this, best to leave it to a shop that does this type work.
Old Dec 27, 2023 | 06:49 PM
doubledragon5's Avatar
Get a pry tool and just gently put under the panel the switches are on and pry up.. I have done this in the past with a older Kia, and it is very simple. It should be held in by plastic clips.
Old Dec 28, 2023 | 06:09 AM
Just because the window doesn't go up or down when you operate the switch does not mean the switch is defective.
Checks for power and ground should be done to verify they are available or the problem will still be there after switch replacement.
rvigil71
Aug 6, 2023 08:13 AM
EricNickerson
Aug 6, 2022 11:11 AM
baronvonkleist
Mar 6, 2021 05:39 AM
TomD
Aug 3, 2019 01:35 PM
PATTISSON
May 25, 2016 02:24 PM
