-   -   Elantra Smart Key (https://www.hyundaiforum.com/forum/hyundai-elantra-17/elantra-smart-key-12148/)
takeitdown Jan 29, 2012 09:41 PM
Elantra Smart Key
This is applicable only for the Limited with Tech Package, which I believe is the only version with the smart key. Does anyone know how to turn off the engine while keeping the Accessory mode on? In other words, be able to turn off the engine and still keep the radio on like every other car with a key? I test drove the Ford Focus with smart key and when you turned its engine off, the radio stayed on until you opened the door. Not so with Elantra. Unless someone knows a solution? I'd hate to waste gas just cause I still want the radio on for a bit before I exit the vehicle.
Also, any ideas how you would start the engine if smart key battery is completely dead? There is a key you can pull out, but I don't see where that could be inserted to start engine.
takeitdown Jan 29, 2012 11:01 PM
Ok, so further reading and testing has answered one of my own questions. If you want to keep Accessories on when turning off the engine, don't put the car in Park. Try putting in Neutral, pressing the engine start/stop button to stop engine and the radio will stay on. Then you have to turn back to On to move into Park. But be careful not to have your foot on brake or else you'll turn the engine right back on again. Clunky, but it's a solution.
NovaResource Jan 30, 2012 08:43 AM
2 Attachment(s)
Pages 5-8 and 5-11 of your owners manual:
https://www.hyundaiforum.com/forum/a...1&d=1327934574
https://www.hyundaiforum.com/forum/a...1&d=1327934580
takeitdown Jan 31, 2012 07:25 AM
Looks like the only way to move the car if the smart key battery is completely dead, destroyed, or lost is to call a tow truck. I'm sure the manual's suggestion to press the start button with the smart key will only work if there's still some juice left in the battery. I guess the lesson is don't let the battery get that low and don't lose it. Someone told me that other Hyundai models with smart key actually allow you to use the embedded physical key to start the car using a secondary key receptacle for emergencies.
NovaResource Jan 31, 2012 09:08 AM
Sonatas have a key dock in the center console. Not sure about the Elantra.
Kathy Welch Dec 11, 2020 01:33 PM
Elantra sport
You can push the button once after shutting off and it will turn on the radio without starting ur car but it drains the battery if you don't have a good one... Unfortunately you can only jump the car off because it's push to start if ur fob isn't working until you replace the battery but ur alarm will go off.
