Heat problems
I have a 2017 Elantra and the car gets up to temp, but will not blow out hot or even warm air unless the rpms are up. What could it be?
What could it be, maybe anyone of the following ?
Faulty thermostat low coolant level restriction in coolant lines to heater core blocked core due to excessive dust accumulation, blend door malfunction Electronic control module for heat/ cooling Dirty cabin air filter Water pump As you can see, it will require some investigating to determine which one or combination could be the cause. |
