Heat problems
Old Dec 9, 2020 | 05:55 AM
Aemtsharp's Avatar
Default Heat problems
I have a 2017 Elantra and the car gets up to temp, but will not blow out hot or even warm air unless the rpms are up. What could it be?
Old Dec 9, 2020 | 08:21 AM
What could it be, maybe anyone of the following ?
Faulty thermostat
low coolant level
restriction in coolant lines to heater core
blocked core due to excessive dust accumulation,
blend door malfunction
Electronic control module for heat/ cooling
Dirty cabin air filter
Water pump
As you can see, it will require some investigating to determine which one or combination could be the cause.
jim4802
Nov 14, 2024 06:21 PM
Judah000
Dec 15, 2020 02:55 PM
polarbear
Dec 1, 2014 06:51 AM
Broly1718
Dec 19, 2012 10:01 AM
barns123
Jan 22, 2008 09:49 PM
