Heater issues with 2003 Elantra
Old Jan 28, 2008 | 12:01 PM
jsiferd's Avatar
Default Heater issues with 2003 Elantra
I drive a 2003 Elantra, and my heater isn't working properly. When I am giving the car gas, it starts to warm up- and when I come to a stoplight, slow down or break at all, it turns cold again. I have had this problem before and replaced the thermostat. At that time, my car was also overheating. That fixed both problems until now, and this winter the heat isn't working once again.
Any suggestions as to what the problem might be?
Thanks.
Old Jan 28, 2008 | 07:20 PM
ken99's Avatar
Default RE: Heater issues with 2003 Elantra
Check your coolant level, I bet it's low. If it is, top it off and then warm the engine up and check for leaks. Look closely for a hairline crack in one of the plastic reservoir tanks or a pin hole in a hose or around the pump. Some place where you are loosing coolant slowly.
Rockygallo
Mar 20, 2014 06:44 PM
blanchard
Apr 16, 2012 05:13 PM
docman56
Jul 21, 2011 07:54 PM
brown1338
Mar 30, 2011 09:48 AM
steelerfan2754
Feb 10, 2010 07:49 PM
