Heater won't turn off even with AC on.
Old Jul 6, 2016 | 12:34 PM
Croth1972's Avatar
Default Heater won't turn off even with AC on.
Hello. You have a great site here! I have a 2007 elantra. Regardless of what temp setting I turn the newly replaced climate control unit to, it blows out very hot air as if the heater is on. The AC compressor is still engaging as I can visually see, and the air is much hotter than if the compressor was just out of refrigerant. Could it be that there is some sort of heater door diverter that won't close properly?
Thanks!
Chris
Old Jul 6, 2016 | 10:42 PM
avisitor's Avatar
There is something called a blend door which sometimes breaks or gets stuck.
It determines which way the air flows.
Yours may be stuck in the heater mode.
Old Jul 7, 2016 | 06:04 AM
Croth1972's Avatar
Thank you avisitor. Do you have any good diagrams that you can point me to?
Thanks!
Chris
Old Jul 7, 2016 | 09:01 AM
Croth1972's Avatar
Ok, so i found it! Its officially called the HVAC actuator. And its on the passengers side. The diagrams i found on another site stated it was on the drivers side, but when i took a look underneath the dash while turning the climate control *****, i noticed that the drivers side controls were all moving when i turned the air position selector ****. So i saw the same type of mechanism (white plastic pieces with slide channels) on the passengers side but they did not move at all when i turned any of the *****. I then took the glove box out and saw the the piece said HVAC actuator. So i disconnected it and physically slid the little white lever toward the firewall and i had AC again! So now ill purchase the part and replace it. In the meantime i can at least reach under the dash and move the lever to the back of the car if i need heat.
Thanks
Old Jul 7, 2016 | 09:07 AM
Croth1972's Avatar
Heres a photo of the white plastic lever with the pin on the pass side after the actuator has been removed. Sorry but the photo is upside down (darn iPad)
Old Jul 7, 2016 | 12:09 PM
avisitor's Avatar
Thanks for coming back and letting us know the fix!!
Old Jun 25, 2019 | 12:02 AM
CrystalC866's Avatar
Same problem im having is it hard to replace? Croth?
moussa854
Oct 7, 2021 03:25 AM
arhhyundaiEL
Dec 24, 2015 12:13 AM
deforss
Nov 27, 2014 04:41 AM
hedr2325
Dec 7, 2010 07:42 PM
travelingman1947
Jun 28, 2006 02:12 PM
