Need ASAP door or
I need to replace the drivers front door due to an accident. does anyone have a door or panel and how does the panel come off.
Anyone?
The Elantra was built from 1990 thru present with 5 different generations. Telling us what year your Elantra is might help.
its a 2012
Door Trim Replacement
https://www.hyundaitechinfo.com/view...n_icon_eng.gif • Be careful not to scratch the door trim and other parts. • Put on gloves to protect your hands. 1.Using a screwdriver or remover, remove the front door quadrant inner cover (A). https://www.hyundaitechinfo.com/data...smdbd1034d.gif 2.After loosening the mounting screws, then remove the front door trim (A). https://www.hyundaitechinfo.com/data...smdbd1035d.gif 3.Remove the inside handle cage (A). https://www.hyundaitechinfo.com/data...smdbd1036d.gif 4.Disconnect the connectors (A). https://www.hyundaitechinfo.com/data...smdbd1037d.gif 5.Installation is the reverse of removal. https://www.hyundaitechinfo.com/view...e_icon_eng.gif • Make sure connectors are connected properly and each rod is connected securely. • Make sure the door locks/unlocks and opens/closes properly. • Replace any damaged clips. |
This is to remove the outer steel panel correct? The actual out door skin.....
Originally Posted by achilliz
(Post 45926)
(Post 45819)
