Need ASAP door or
Door Trim Replacement
• Be careful not to scratch the door trim and other parts.
• Put on gloves to protect your hands.
1.Using a screwdriver or remover, remove the front door quadrant inner cover (A).
2.After loosening the mounting screws, then remove the front door trim (A).
3.Remove the inside handle cage (A).
4.Disconnect the connectors (A).
5.Installation is the reverse of removal.
• Make sure connectors are connected properly and each rod is connected securely.
• Make sure the door locks/unlocks and opens/closes properly.
• Replace any damaged clips.
The outer skin needs to be cut off. Go see a body shop.
UWNTM3
Mar 2, 2010 10:13 AM
