output speed sensor 01 elantra
Old Mar 26, 2010 | 04:13 PM
justinb1022's Avatar
Default output speed sensor 01 elantra
im looking at a 2001 elantra for a friend, and the check engine light is on. so they took it to the dealer and got the code p0720. output speed sensor. does anyone know the best way to change one of these, maybe a picture of its location. any help is appreciated. thanks.
Old Mar 26, 2010 | 05:12 PM
Sensor is out in the open in most respects, mounted over top of the output shaft of the transmission,, sorta in front/beside/below brake master cylinder. Need a long 1/4 drive extension with 10mm socket, remove the bolt, carefully rotate sensor side to side and lift... then carefully release the connector from the sensor.
I apply a dab of lube to the o-ring on new sensor so it will pop into the hole easily, re-install bolt (snug),, then plug in connector carefully and straight till it "clicks"... clear code and drive.
Old Mar 26, 2010 | 09:59 PM
thanks. now all i have to do is order one. thanks.
Old Mar 27, 2010 | 08:50 AM
Order 1 ??????? We usually have 3 or 4 on hand at a time.....
ejc2180
Apr 23, 2021 01:55 PM
DCCD
Feb 17, 2011 08:01 AM
redbijou
Nov 1, 2010 01:30 AM
GOODWAY
Jan 21, 2009 08:30 AM
omnipotent goku
Jun 3, 2008 09:23 AM
