Radio & Clock not working in 2002
Okay, so I made a mistake in replacing the battery in a 2002 Elantra- I started to put the cables on the opposite terminals and you can guess the result... a sparking surprise. I immediately switched the battery around, but now the radio and clock in the car do not work. I checked all of the fuses in the cabin and those in the engine compartment, but they all checked out fine. Any thoughts on what happened and how I can fix this issue.
Thanks so much!
Thanks so much!
from some of my reading it seems highly likely that the radio has an "in-line" fuse protecting the unit. Does anyone know where this is located? Would it be in the engine compartment or behind the radio?
Thanks to anyone that may know the answer.
If the radio, and the clock, and oh, say the door courtesy lamps, the trunk lamp, the dome lamp are all out, check Fuse 25 in the Passenger Compartment Fuse Box, the one at the right end of the bottom row:
I know you said you checked the fuses, but that's the one that controls all the stuff I listed. If it's not that, and those lights and stuff work, you may have a problem with your ETACS, the unit that controls your alarm and a lot of other functions in the car.
Thank you for your response.
Now that you mention it, I do notice that the overhead light and door lights do not work as well. Fuse 25 was burned out originally when I checked the fuses, so I replaced it- unfortunately this didn't cure any of the issues.
Are the ETACS and the TACS separate systems? I saw on the HMA service website that they list them separately. Are these units something I should attempt to replace or am I at a point where it would be best to let the professionals at the dealership figure out what is going on?
I appreciate any help that you can provide.
ORIGINAL: pamador
Thanks so much!
Thanks so much!
