Rear Alignment issue for 2008 Hyundai Elantra?
I was wondering if there is anyone else out there who has been told that their Elantra was built out of alignment. My car has been at a Hyundai dealership for 2 weeks, and they have finally informed me there is nothing they can do to fix the way the tires ride on edge because the car was built that way.
The reading on my alignment printout from a reputable alignment shop shows that the camber is at -1 3/4 on both the right and left sides of the rear. I was originally told by the dealership that my car was out of specs and they needed to proceed further to their technicians/engineers. Then, I received a phone call that the car was actually within specifications and is naturally designed to ride that way. When discussing the issue with my mechanic and alignment mechanic they informed me that due to this structure of the frame it will cause my tires to wear out and they can not properly align my car. Is there anyone else out there that has this same issue, or has noticed their tires tilt in at the top? |
Simple solution is to drop the camber to "0",,,, no more than -1/2*....
Specs is a bunch of crap. I want to see numbers that is square, no excessive spread, and straight. Set the camber to as mentioned above, and total the rear toe at no more than .08* total (0.04 per side) with thrust = to 0.0 at rear, even out your front camber with the natural slop of the knuckle to strut bolt holes, keep it to less than 1/2* spread side to side, set front toe to 0.08 max at front, and you will have a nice responsive feel to the steering and decrease your tire wear issues considerably. Got your current numbers of the align you riding on now ? |
I am not a mechanic but from what I understood that they told me at the dealership was: "the car was built that way and they cannot adjust the camber"
The front left side is: -1/2 degree Camber, -3/64in toe The front right side is: -7/8 degree camber, -1/32in toe The left rear is: -1 3/4 degree camber, 11/64in toe The right rear is -1 3/4 degree camber, 3/64in toe Like I stated, I was told that the rear cambers could not be adjusted because the car was manufactured that way. I am only going by what they told me. If you have any suggestions I appreciate it. Thanks, Andrew |
Originally Posted by alatini
(Post 27613)
The front left side is: -1/2 degree Camber, -3/64in toe The front right side is: -7/8 degree camber, -1/32in toe Front has .3* camber spread, nothing exciting there, though I do not like toe-out, gives car a loose feel, turn wheel slightly before car reacts.. I prefer toe-in, touch the wheel, cars reacts quicker The left rear is: -1 3/4 degree camber, 11/64in toe The right rear is -1 3/4 degree camber, 3/64in toe On the rear, I prefer minimal camber, and near "0" to no more than 0.08* toe in, too much toe in and rear will come around rather quick, Toyota Camry used to blaze tires on rear and over-steer something fierce with their gross amount of toe-in.. Like I stated, I was told that the rear cambers could not be adjusted because the car was manufactured that way. I am only going by what they told me. If you have any suggestions I appreciate it. Now to answer your question... I did grab '08 Elantra service manual before I left... it states the rear camber is set at manufacture, and is non-adjustable... replace parts to correct camber if out of spec... Get this,, the manual calls 1 degree, +/- 1/2 degree.... sound like there could be a wide open market for somebody to sell adjustable links or what ever to re-camber the rear of the Elantra to get closer to "0" degree... We did not have any "HD" Elantras in today that I seen after reading your post, but now I will have to keep eyes open and go look at 1 to see what "could" be done... Thanks, Andrew |
Thanks for all your help. I appreciate it, you answered a lot of questions for me.
If you find out anything more, please post it! Thanks again |
Had an HD model in the other day for oil change, so I went over to other techs area and snooped around..
Only way to get camber reduced would be to shorten the lower arm, as it is fixed length/mounting at knucle and crossmember... problem with that is the rear spring sits on that arm.. Rear uses (3) links to hold the spindle in place and allow travel.. somebody would have to likley cut the rear lower arm, and replace end with something similar to the adjustable link used in a "4 link" race car mounting, then end result would be a degree of noise that only a performance minded person would not take issue with.. or just find a way to bend the arm to make it shorter to get desired camber. |
Thank you for the posts. This is my car too. The rear tire wear out on the edge and those who have looked at it say no adjustment.
What do you think of a X tire rotation? Each set of tire we have had have wore out early. We have been able to get credit on the tire towards the next set. Any new information? |
Tires and alignment issues
On my fifth set of tires(160,000) miles. Other than the tire issue this has been a great vehicle.I will report this as a vehicle defect and let the big boys handle it.
Originally Posted by missileone
(Post 50527)
Nova,I didn't say I had a tire issue. I said I was on my fifth set of tires at 160,000 . Two sets were suppose to last 160,000. I have a alignment problem genius.
| All times are GMT -5. The time now is 09:50 AM. |
