Removing trunk lock
2005 Elantra 4-door
The previous owner rekeyed the trunk lock, but there's no key, and I can open it only with the latch on the driver's side floor. I want to rekey it for my ignition key. How do I remove the lock? |
Open trunk and access rear side of lock
There should be a "C" clip Remove clip and lock should come apart. Unless you have a different lock |
No, not a diff lock, I think. Just want to rekey it to my ignition key. Many thanks! :-)
There is no way to rekey the lock. You replace it.
Any locksmith can re-key the lock.
But, probably easier to buy new lock. |
One key for both is my preference, but I'm open to a new lock. The cylinder is removable, so I'll talk to my locksmith and compare prices. Thanks, guys.
Oops, I've gone in a few times with a flashlight, and there's no C-clip. I still can't figure how it comes out.
If it is a lock cylinder there may be a nut near the trunk wall
Look at lock from outside. The cylinder could be threaded and a nut threaded on to hold it against the trunk hood OR Sometimes there is trim or a panel that must be removed to access the trunk lock Once removed then you should be able to see the inside of the lock Three nuts should be holding the lock in place. Remove with socket set Lock should come out Check out youtube They might have a video with your car??? |
These nuts can be replaced by own without taking help from a locksmith.
Originally Posted by DonaldGrace
(Post 57706)
The OP wanted to re-key the trunk lock. He just wanted some help to remove the trunk lock. |
| All times are GMT -5. The time now is 07:03 AM. |
