Unable to start car in neutral
Old Jan 7, 2008 | 03:56 PM
luftwaffle's Avatar
Default Unable to start car in neutral
Good afternoon, everyone.
I am normally not one to take part in these types of forums, but this morning I came across a problem that is quite inconvenient. I own a 2004 5 speed Elantra, which has been my daily driver since it was bought new. The car has not been starting when the gearbox is in neutral, it just clicks as if the battery were dead. However, when I start it in first gear, it fires problem free. Has anyone come across this problem before? Any insight as to what the problem may be?
Old Jan 8, 2008 | 09:14 AM
Doohickie's Avatar
Default RE: Unable to start car in neutral
That is a strange problem. My guess is that there is a loose conneciton on the starter and when you put it into first gear, the engine rocks just enough to make the connection. That's just a guess though.... but maybe start by checking your electrical connections to the starter.
Old Jan 8, 2008 | 02:42 PM
madindian1's Avatar
the car isn't going to start in neutral unless you press the clutch pedal(guessing that you're not) so when you put in 1st gear you have to press the clutch that's when it will start. just my 2 cents since i'm not around the car to diagnose the problem.
Old Jan 8, 2008 | 09:03 PM
luftwaffle's Avatar
ORIGINAL: madindian1
Nah, I'm always on the clutch at startup whether it's in neutral or not. Thanks for the input, though.
I'll look into your suggestion, Doohickie. Seems like a possible culprit.
Old Jan 8, 2008 | 09:16 PM
gramps's Avatar
look into your neutral safety switch . it could be malfunctioning
Old Jan 9, 2008 | 03:51 PM
AManiscalco2007's Avatar
Could be the neutral safety switch..
itsthebigb19
Oct 4, 2017 01:05 AM
word2yamutha
Sep 2, 2015 11:17 PM
daniel2229
Nov 4, 2013 07:27 AM
beach12330
May 29, 2009 04:37 AM
pacwestuk
Feb 14, 2008 07:16 AM
