Wheel Lug Torque Specs
Old Dec 28, 2019 | 10:56 AM
  #11
I always remember when a shop/mechanic wasn't sure of how the system worked they always replaced the alternator and regulator ,"Just to be safe" That added extra cost and work that was not necessary and today time is $$$.
The same logic apples here regarding lug nuts and bolts. There are folks that get paid a lot of $$$ because of their education and background with metallurgy that come up with these specs and there is a reason for using the specs. If someone wants to stretch the studs on their vehicle by over tightening them , that is their choice.
A lot of us get away with excess tightening and nothing happens. The rotors out there today are not as heavy as the older ones so they do respond quicker to over tightening.
Old Sep 19, 2021 | 02:15 AM
  #12
zico's Avatar
Default Yeah but I don’t ever recommend 100 ft lbs or above. The highest you can do is 90
Yeah but I don’t ever recommend 100 ft lbs or above with small cars. The highest you can do is 95 ft lbs that’s it.
Old Feb 9, 2022 | 03:39 PM
  #13
braveheartbc's Avatar
Default torque lug nuts too tight
Originally Posted by avisitor
Don't know about 2017 Elantra
But, most cars have the torque spec around 100 to 125 foot-pounds.
if you torque the lug nuts way over spec they will snap clean off when you try to loosen them unless you are old school like myself i know how to give them a slight more snug then back them off . torque them at 80 lbs if you like them tight
Old Feb 14, 2022 | 12:10 PM
  #14
DenHy1$'s Avatar
Originally Posted by sascher18
anyone know what the wheel lug nut torque specs for a 2017 Hyundai Elantra Limited?
95 ft.lb. Should keep you safe- 1/2” lug specs are 95-105.
Old Feb 14, 2022 | 01:18 PM
  #15
I believe that info is located in your owner's manual under specifications.
Old Oct 27, 2023 | 06:05 PM
  #16
Ng18's Avatar
Default 2017 Elantra Specs
Hope this helps.
galan747
Nov 20, 2014 08:25 PM
bigrob
Nov 19, 2013 04:04 PM
oknaz
Nov 4, 2010 11:37 PM
gunwaleman
Nov 14, 2009 06:54 PM
spoonanator
May 16, 2006 12:30 AM
