Diagnostic Help! i30 (1.6L unleaded) stalls at traffic light and doesn't restart
Old Jun 11, 2022 | 03:09 PM
thekswenson's Avatar
Default Diagnostic Help! i30 (1.6L unleaded) stalls at traffic light and doesn't restart
My i30 just stalled at a red light. It did restart, but was idling extremely weakly and poorly. The gas pedal did not effect the idle at all. I stopped the engine and restarted it this way a few times, only to have the same very weak idle. At this point the car will no longer catch at all.
I figure that the problem is either the spark or the fuel delivery, given that the starter cranks without a problem. Here are some related facts that may be of note:
  • I changed the spark plugs only last year
  • I changed the camshaft position sensor a little over a year ago (after not starting at times, and engine code)
  • The car has been taking one or two more cranks to start lately, but it does feel out of the blue
  • no code has been tripped
  • I had little fuel in the car. it was above 0 though, and I added more fuel without effect
Any ideas would be greatly appreciated! The car is currently parked on the side of the road.
Old Sep 6, 2022 | 10:14 PM
Endeavor's Avatar
Did you figure out whst the issue is... it may help others ..
i would suggest clean the ait intake and THrottle body
Old Oct 21, 2022 | 10:42 AM
The problem was the fuel pump. It was very easy to diagnose since, when I turned the key to the on positions, there was no "whine" heard from the pump. It was also very easy to change!
Old Oct 23, 2022 | 08:04 AM
Thank you for sharing that solution with us.
ezauto
Apr 15, 2024 05:45 PM
DevilInWings
Sep 13, 2020 06:06 PM
Annette
Mar 3, 2020 05:26 AM
E.T.
Jul 21, 2009 11:25 AM
