Driving Lights?
I apologize if this was already asked but I didn't see anything. I have a 2010 Touring GLS model that does not come with the lower driving lights. I would really like to have the OEM lights installed. Does anyone know if this can be done? I know that there is a question about the switch, the switch in the SE model is in the head light control lever, but I'd be willing to just have a switch put in the open spot I have next to my esc switch.
Thanks |
fog light?
fog/driving lights, the 2 lights in the lower front bumper.
Yes, it can be done. As for the location of the switch should be perfect. Remember to tie the electric to a relay and have the power to the relay series to the relay coil. Do not tax any circuits.
In other words the main power from the battery to the contacts of the relay, The coil to your switch and the coil power from the off line power circuit of the key. These lights if left on will drain your battery very fast. |
Thanks for the info DrD gonna see about getting the OEM lights and hook them up. I figure if I have the same wiring harness as the SE model then everything should hook up and the only issue I'll have is for the switch. Thanks Again!
Originally Posted by Ranger524
(Post 29109)
Bernie |
Thanks Bernie for the info, If I get the OEM light housings and bulbs is there a certain type of (rated) wiring and relay or will any standard fog light wiring pack suffice?
Thx |
(Post 29357)
Thx |
Thx Bernie for all the info I will talk with my local autoparts dealer and see if we can come up with something.
