how to remove oil filter-touring 2010
I HAVE TRIED REMOVING OIL FILTER BUT ITS TO TIGHT...WHAT SIZE OIL CAP TO REMOVE FILTER DO i NEED..ALSO TRYED CLAP ON WRENG NOT ENOUGTH FORCE TO LOOSE FILTER.. Help
If you are having trouble removing an oil filter, maybe you should take it to a qualified mechanic.
I've never been a fan of dealeship oil changes, but this is the best reason in the world to take advantage of the freebie oil change offered by most dealerships on new cars. I thought this was strictly a Hyundai problem, but I recently purchased a new Dodge Ram 1500 (the Explorer is gone, long live the Explorer) crew cab with the same problem, only worse. The filter on this engine is oriented straight down, easy access. With my stoutest oil filter wrench, an extension handle and my foot braced on the frame rail, I couldn't budge the filter loose, actually started to crush and put a twist in the can. I stopped before I created a puncture and then redeemed my coupon. I can't imagine what the companies are doing to glue filters on this tight without stripping the threads.
Interesting but sad!. Did you by chance see how dealer removed filter.
A good strap wrench should get it off. Either a metal one with small gripping spikes or a rubber one. Try spraying some penetrating oil around the gasket where it mounts to the block. If all else fails, use large plyers and crush the filter if needed or drive a large screwdriver through the filter case and crank it off.
Be sure to put oil on the rubber gasket of the new filter when replacing it ot it will stick again. And only tighten it by hand. 3/4 of a turn after the gasket touches the mounting flange. Metal: http://www.homedepot.ca/wcsstore/Hom...df993083_4.jpg Rubber: http://www.northerntool.com/images/p...1501539_lg.jpg Plyers: http://a1toolsales.com/images/oil%20filter%20wrench.jpg Compression "socket": http://toolmonger.com/wp-content/upl...r%20Wrench.jpg http://valuesetters.com/vendor_10_pr...ges/648659.jpg http://www.1130cc.com/gallery/files/.../p0034603x.gif |
Originally Posted by lon
(Post 31081)
Will provide more info later but problem has been taken care of. First I have been took by two different people that during manufactorying a machine puts the filter on and that accounts for the tight fit. I also found that my dealer uses the oil cap and lube place uses oil plyers. Furthermore under the car you must take off the plastic shield that cover part of the oil pan and access to oil filter..I think most of us know about that but what I did not do was remove a second plastic shield (to right of first plastic shield) and that allows greater access etc etc. I still dont know the size of the Touring OEM filter (oil cap) but will post when I find out. I hope this help someone. Above picture of oil removing tools are great but metal strap type did not work for me.
is it hard to get to ? like my Nisson truck? but it is at 179.000 miles ,and I do my own
oil changes on it . But I have the first one free! on the ET. if they do it right?? I don't trust Dealers, here is a good point though, my frind alway's took his wifes car 2001 Mustang to the Dealer for all oil changes from New! The Tech that day had a brain%&** And left the drain plug loose, He got about 2 miles when the hot light came on then if he would of shut it off right then if may have been fine? just stuck in the road, with a oil line from the dealers shop!! but he was at a red light! & was trying to get over to the side ! Now with all the oil gone the Motor locked up, & had to walk back to the Dealer. with about 130.000 on the Mustang that high mile for a 4 banger! the best part ! He got a new motor & a car to drive from the Dealer. The Tech got the boot. |
