Winter tires pressure
Old Nov 2, 2010 | 10:39 AM
  #11
delta426e's Avatar
Banned
That's correct, winter tire pressure should be the same as the summer.
For 32-35 psi passenger car tires the pressure decreases 1 psi for every 15 deg F the temperature inside the tire goes down. Keep in mind that you need to add a little air to the tire in colder temperatures. This will give you the same cold inflation pressure as you had on those nice warm summer days.
Old Nov 2, 2010 | 11:00 AM
  #12
Actually, the pressure in winter tires should be higher because winter tires are softer by design.
http://www.tirerack.com/winter/tech/...jsp?techid=168
Actually, it's a 1 psi drop in pressure for every 10 degree Fahrenheit drop in temperature. So if your tires were at 32-psi when it was a warm 80-deg late-summer/early fall day not that the temps are in the low 40's for the late-fall, the tire pressure will be at 28-psi even if the tires didn't lose any air.
http://www.tirerack.com/tires/tirete....jsp?techid=73
Always check your tire pressures monthly!
jaybo
Jan 24, 2011 05:35 PM
michdet
May 14, 2010 08:04 PM
karla
Jan 5, 2009 09:59 AM
iancanada
Dec 5, 2007 09:14 AM
Firebane
Jan 5, 2007 06:44 PM
