-   Hyundai Entourage (https://www.hyundaiforum.com/forum/hyundai-entourage-43/)
-   -   Changing rear wiper blade (https://www.hyundaiforum.com/forum/hyundai-entourage-43/changing-rear-wiper-blade-10194/)
Kodge Jan 27, 2011 09:11 PM
Simple task, simple question maybe - but can anyone give me an idea of how to change the rear wiper blade? Picked one up from the dealer when passing by (found a thread about cheaper options a few minutes ago...), checked the manual and it suggest the dealer do it to avoid damaging parts.
NovaResource Jan 28, 2011 07:41 AM
If you bought a factory blade it actually replaces part of the arm itself. Just lift the arm slightly and pull the blade and arm off away from the pivot point. Look at the replacement blade and you will see.
Kodge Jan 29, 2011 10:39 AM
LOL, thanks for the info Nova - that took all of 20 seconds. No idea why they don't explain that...
zachunderwood Feb 9, 2011 07:48 PM
Here's a DIY for changing the rear wiper
3 Attachment(s)
Remove the cover from the rear wiper blade
Attachment 1772Attachment 1773
Step #2 .. Use a 12 mm socket to remove the nut in the middle and pull off the wiper arm. Now, this is just like changing the blade on the front wiper.
Here's a quick photo of the receiving arm to hold the new blade.
Attachment 1774
NovaResource Feb 9, 2011 08:12 PM
http://i28.photobucket.com/albums/c2...ood/Wiper1.jpghttp://i28.photobucket.com/albums/c2...ood/Wiper2.jpg
You do not have to remove the wiper arm from the vehicle to change the blade.
zachunderwood Feb 9, 2011 09:06 PM
:)I'm sure you're right on that. I just thought that with my luck, I'd end up breaking something.:D
sbr711 Mar 22, 2011 07:06 PM
You're lucky you did not twist the nut off top of the shaft..
Did a Tucson today, raise blade off widow, pop the tiny blade off, snap new blade on,,,,,, all done
NovaResource Mar 24, 2011 03:09 PM
3 Attachment(s)
Here's the pics from my van. Just pull the arm up off the glass and while holding the rear part of the arm, pull the front half off.
https://www.hyundaiforum.com/forum/a...1&d=1300997307
https://www.hyundaiforum.com/forum/a...1&d=1300997313
https://www.hyundaiforum.com/forum/a...1&d=1300997321
