Check engine light, ABS light, No cruise
My entourage has the check engine light on as well as the abs light and the cruise does not work, I have a scanner and got code p0501 which is speed sensor issue , After doing some reading it seems all three problems could be related does anyone know where the sensor is located so I could have a look at it and see if it needs replacing
