Hyundai Forum Help & Suggestion Center Need help with HF? Ask! Have a suggestion to better HF? Tell us here..
2005 Hyundai Terracan 4WD problem
Old Jul 19, 2021 | 11:44 PM
Did's Avatar
Did
Unhappy 2005 Hyundai Terracan 4WD problem
Hi
My 2005 Hyundai Terracan 4WD has been making these huge shuddering, bangs under the front of the car- almost like I have hit a huge tree stump on the road. It usually does this a minimum of 3 times over a 7-10km distance. Sometimes if just totally stalls after doing this. Great when on a highway doing 100km an hour.
Other times it just stalls when idling or when going slow in a shopping centre. Takes 3 attempts to get it started again.
My car has now been in the Hyundai workshop for nearly 5 weeks now.
No one seems to know what it is doing. Replaced the battery, replaced the cable between the alternator and the battery. Have done the flight mode testing which shows it is electrical but that keeps changing.
it is terrifying to drive as I never know if it is going to stop working on the highway with big trucks around me.
Please- any help would be so much appreciated.
Old Jul 20, 2021 | 08:20 AM
I would be very suspicious of the 4 wheel drive system.
Could you please explain ,
testing shows it is electrical, but keeps changing?
I ask this because I am wondering how something electrical can produce a banging?
Old Jul 21, 2021 | 12:16 AM
Did's Avatar
Did
Hi Hanky
The service people at Hyundai said when they put the fight mode sensor on it shows up different links. But they are not certain what that means. They said they are working in conjunction with the Hyundai manufacturer.
The bangs are almost like explosions. They reckon they have tested the air input and output when I asked if it was something like what happened when cars were changed from petrol to gas.
it will be 5 weeks tomorrow and still no solution. If it is the master computer, would that be expensive?
thanks
Did
Old Jul 21, 2021 | 05:39 AM
It is possible the servicing agency has not had many calls for this type problem, so it will take longer to pin down the cause.
Old Jul 22, 2021 | 01:02 AM
Did's Avatar
Did
Thank you Hanky. Fingers crossed they can fix it as it is a beautiful car. Has only just over the 100k kilometres and always been serviced by Hyundai.
Radu Chirciu
Off Topic
Feb 24, 2020 08:18 AM
Scipiokid
15
Dec 30, 2019 04:37 PM
Ben Judkins
Jan 17, 2017 07:18 PM
greenhornet923
Apr 23, 2007 06:26 PM
pentecostjw
Dec 30, 2005 02:42 PM
