Hyundai Forum Help & Suggestion Center Need help with HF? Ask! Have a suggestion to better HF? Tell us here..
Accent 2012 clutch problem
Old Jul 4, 2020 | 01:25 PM
HWDE75's Avatar
Default Accent 2012 clutch problem
Hi All,
I have an Accent 2012 GLS manual transmission and the clutch pedal went limp. When you depress it the slave cylinder pin moves very little.
I am thinking the master cylinder is the problem here and want to replace both the Master and Slave cylinders at the same time.
Question is am i diagnosing the problem correctly and how difficult a task is this? Any tips and advice would be very welcome.
Thanks in advance.
Old Jul 4, 2020 | 01:54 PM
We always check some things before condemning parts.
Since you didn't say, what is the level in the clutch master cyl look like?
Old Jul 4, 2020 | 07:44 PM
HWDE75's Avatar
hanky,
The reservoir is shared with the brake reservoir and the level is good.
Old Jul 5, 2020 | 06:06 PM
HWDE75's Avatar
Yes.
The brake master and clutch master draw from the same reservoir. The reservoir is situated above the brake master and there is a pipe off the right hand side that leads down to the Clutch master.
Old Jul 6, 2020 | 12:49 PM
I did confirm that Hyundai does share the same reservoir. . How is the brake pedal working ?
Old Jul 6, 2020 | 09:29 PM
HWDE75's Avatar
The Brake pedal is working just fine.
The clutch just has no tension at all - i can push it down to the floor with my hand.
Old Jul 7, 2020 | 06:36 AM
If the level in the shared reservoir is good, there has to be a separate master cyl just for the clutch. That is where I believe the problem is located.
Old Jul 7, 2020 | 08:34 PM
HWDE75's Avatar
Hanky,
Thanks. That was my thoughts too. There is a separate master for the clutch, its just doesnt have a reservoir attached to it. I was going to replace this first and then see if it operates correctly. If not replace the slave too.
Old Jul 8, 2020 | 05:33 AM
I believe you are on the right trail replacing both. Every time the master operates so does the slave. Do it all and do it once.
Old Jul 8, 2020 | 08:28 PM
HWDE75's Avatar
Thanks for the help. Thats what i was intending to do, and your replies affirm that i am doing the right thing.
Cheers
HWDE75
bannaga
Oct 23, 2019 05:27 PM
mark5soup
Feb 18, 2018 08:33 PM
chuds
Oct 4, 2011 11:37 AM
