Hyundai Getz not starting
My 2006 Getz will not start. It cranks but will not start up. The dashboard lights do come on, but the fuel light stays on even though it has a full tank of fuel. Some guys recommended I check the crankshaft sensor, I'm not sure where it's located...Anybody ideas?
hi am new too the getz but while i was searching the net to see what possible problems they may before buying i came across the problem you are describing.
someone else on another forum had this problem would crank and not start and it was fixed. they said it was a sensor or sending unit attached to the starter. have no idea if this helps but might be worth checking out .. sorry i cant remember where i read this.. |
