Hyundai Matrix This sub compact hatchback offers excellent interior room for both passengers and cargo.
replace front and rear engine mounts
Old Feb 4, 2020 | 04:31 AM
louis_france's Avatar
Default [SOLVED] Replace front and rear engine mounts
Hi everybody
I am planning on replacing the front and rear anti-roll engine mounts, while supporting the engine with a jack.
Any recommandations ?
Thanks
Old Feb 4, 2020 | 04:08 PM
If you are planning to lift the engine by placing the jack under the oil pan, make sure you place a piece of wood between the jack and the oil pan or the jack could go through the pan. The idea is to spread the lifting force out and not concentrate it in one place because the oil pan is not designed to support the weight of the engine.Something like a 2X6 approx 1 foot long.. Make sure it extends past the edges of the pan to spread out that force. The ideal procedure is to use a lifting tool designed to lift the engine by the lifting eyes on most engines.
Old Feb 4, 2020 | 10:08 PM
avisitor's Avatar
Yeah, what Hanky said.
Do not lift the engine and car up by the oil pan
Only support the engine with wood and jack
BTW, why are you changing motor mounts?
Did you inspect them and tested them?
Old Feb 29, 2020 | 03:56 AM
Thanks a lot for your advises.
I managed to lift the engine and replace the engine mounts.
Yes the silentbloc were torn and needed replacement
Old Feb 29, 2020 | 05:38 AM
Most folks have no idea what happens when you tramp down on the accelerator pedal for a fast getaway.
This places a lot of torque force on the motor mounts and can in some cases RIP them apart.
A lot less expensive to just drive normally or don't make a practice of jack rabbit starts.
Old Feb 29, 2020 | 04:06 PM
Haha you're right !
'm no good at slow starts for sure. I like to start promptly
Explorer99
Oct 30, 2016 06:24 PM
blueshark
Mar 19, 2012 03:45 PM
NH_Lakes
Feb 17, 2012 12:54 PM
meld
Aug 5, 2010 06:53 AM
Charlie1969
Dec 14, 2008 07:42 PM
