04 Santa Fe Cv joint replacement issue
Old Jun 7, 2012 | 05:48 PM
loopin6565's Avatar
Default 04 Santa Fe Cv joint replacement issue
ok so i decided I would change out the passanger side cv joint for my girlfriend, after hearing it clicking etc. I got the whole half shaft for it. I got the side of the cv joint out of the brake caliper so its hanging down on that side. My issue being the other side of the half shaft, the side that is connected to the transmission will not come out. Everything i read online says just pry it or pull it. I have spent hours with chains pry bars everything and it will not pop out of the transmission. Does anyone have any sugestion or previous experience with this that could help? It would be a lifesaver. It is a 04 santa fe 3.5l awd
Old Dec 1, 2013 | 06:50 AM
derek01's Avatar
hi some times you have to get under the car with a long chissel and hammer where it enters the gear box on a lip hit it hard rotate hit again it will come. good luck
Storm7758
Feb 28, 2009 06:45 PM
Policy Peddler
Apr 29, 2008 12:47 PM
nageshbr
Dec 27, 2007 09:56 AM
xxfroehlichxx
Nov 12, 2007 09:51 PM
John Brodzinski
Mar 3, 2006 03:32 PM
