04 santa fe runs like crap,eats fuel -no codes..
I did a search on brown muck in the fuel tank and found that some boaters are having trouble with brown muck in their tanks and clogging fuel filters. It seems the ethanol absorbs more water but cannot process it, it then turns to muck and clogs things up. I've been going to a new gas station for about a year that states right on the pump that their gas has up to 10% methanol in it Could this have caused my problem? Could I have been accumulating this muck over the course of a year to the point of where It is now?.I have never ever had a problem like this in the past and my vehicle is not real old only 5 yrs.
I think all gas in the US is 10% ethanol. Some places it's 15%. I don't think it's your problem. If you keep your tank near empty in winter, that makes a lot of condensation in the tank. In the old days we would buy "dry gas" additive and put it in the tank, but if you keep your tank full, you won't have that problem.
Boats have a problem because most people don't run them enough and the gas will separate in the carburetor. Or condensation forms in the tank from all the moisture.
Just to clarify, did this problem start after the time belt change? It could be a tooth off, easy to do and would cause the problems you are having. Noisier exhaust could indicate such a timing problem.
If you are still thinking dirty fuel injectors try a can of BG44k with tank full of the top grade Shell gas.
I'm still having a problem. It seems somewhat better but its still not like it should be.The problem was already there before the timing belt change. Where can I get some of that B44k?
the problem is its a santa fe 3.5. its a pig on gas. you can try cleaning the throttle or paying for a BG intake cleaning as the runners do get clogged up, however as a technician i would honestly suggest pushing it off a cliff and collecting the insurance money thus investing in other santa fe powered by the far more reliable and just as powerful 2.7.
Forget used 2.7L Santa Fe's. Personally, I'd trade it in on a new Santa Fe with the even more powerful and refined 3.3L Lambda engine. And Hyundai is giving big discounts on the Santa Fe and most of their lineup.
