Replacing fog light in 2007 Sante Fe Limited
from http://www.hmaservice.com:
SANTAFE(CM) >2007 > G 2.7 DOHC > Body Electrical System > Lighting System > Front Fog Lamps > Repair procedures
REPLACEMENT
1.Disconnect the negative (-) battery terminal.
2.Remove the front side cover screw.
3.Remove the front fog lamp assembly (A) after loosening screws (4EA).
4.Installation is the reverse of removal.
If just replacing the bulb, I think you can just reach up underneath the front bumper, turn the bulb base CCW and then remove it from the fixture.
REPLACEMENT
When I replaced the fog light bulbs on my wifes 2006 Sedona minivan I could only access them from the top. You might have to do the same thing and remove the plastic cover over the radiator and grille area under the hood to access the sockets.
lavangbay
05-21-2011 07:13 PM
