2005 Santa fe whirring,whistling, whining noise
Old Nov 17, 2015 | 11:03 AM
bwrumfel's Avatar
Default 2005 Santa fe whirring,whistling, whining noise
My 2005 Santa Fe makes a strange noise when tacking up that sounds almost like a turbo spooling up and down. It usually starts this shortly after start up and I drive about a mile. Sometimes it's immediate on take off. If I just sit and idle no noise. If I just sit and tach up the engine, no noise. Just when I'm in gear and driving while accelerating and taching up the engine. When I let off the gas it stops completely most of the time. It's difficult to zero in on a location since it only sounds off while in gear and driving. It will do it in all gears but seems to lighten up as the transmission up shifts to higher gears. Does anyone have an idea. I am afraid to drive it at this point since the noise progressively got worse over time. Initially when I detected the noise it seemed to have a loss of power and would not tach up normally. Now I've got a loud whistling noise but it seems to have normal power and acceleration. A few weeks ago I did replace the Engine Misfire Sensor because my tachometer stopped working and I had misfires on all cylinders. This sensor got rid of the DTC codes and fixed the Tach. Sorry for the book but Thanks for any help for anyone.
Bill
andreah1
Sep 22, 2014 12:53 PM
luvdodge
Feb 13, 2014 06:33 AM
jgdemos
Nov 1, 2011 04:09 PM
manny
May 11, 2011 08:44 AM
catbeckster
Jun 8, 2005 01:23 AM
