2007 Hyundai Santa Fe door lock problems
Hello I own a 2007 Hyundai Santa Fe. The problem I am having is the passenger side door locks do not operate by either the remote or the use of the power door functions used manually within the car. I am able to lock and unlock the doors by manually moving the individual door locks. I checked all fuses and the appear ok. What could be the problem. The drivers side works we'll as doses the rear hatch.
Mine has the same problem...Did you ever find out what the problem is?
Probably the lock actuator needs replacing
But first should check to see if unit is getting powers and grounds And/or operates when provided power and ground |
