2007 Santa Fe A/C fuse blowing
Old Aug 6, 2013 | 03:21 PM
daniel2229's Avatar
Default 2007 Santa Fe A/C fuse blowing
Twice now the A/C 10 amp fuse under the hood has blown. Once in very hot weather and once today in cooler 77 degree weather. Both times I have been either had my boat hooked up to the vehicle.
First time we had taken the boat to the lake. I knew the air was off because when I went to retrieve the boat, the air was not working.
This time I hooked up the boat to get gas, and when I got back to the garage, the air was not working. I'm not sure exactly when it went out as I had the windows rolled down.
I am wondering if there might be an issue with my light harness to the trailer? Or maybe it is just a coincidence. The boat is only 17' long and well under the towing limit of 3500 pounds. It maybe weighs 2200 trailer and all.
What do you think? I am kind of wondering before I take it to the dealership.
Thanks,
Daniel
Old Aug 14, 2013 | 05:05 PM
daniel2229's Avatar
Went to the dealer and had a new compressor installed. Compressor cost $320 or so and labor was $275.
Old Sep 4, 2013 | 06:48 AM
Erichshonda's Avatar
All you needed is the field coil replaced.!when they go bad. They short out internally and blow the a/c fuse.
Old Sep 8, 2013 | 04:21 PM
daniel2229's Avatar
I mentioned something to that effect, but it wasn't an option they gave me.
I have a pretty good relationship with my service department, and they have never pulled what I would consider a fast one. If they did this time, it was the first.
The Hyundai dealership is one of those where a name owns four or five different brands, and they are noted in the Dayton area as being pretty straight forward.
I remember having an really nice '87 Bonneville and took it to the Pontiac dealership in Xenia, Ohio. On the way back home, the engine started acting funny, so I turned right around and went back. They had left a couple of parts unconnected and made it sound like I had done it on my drive home. I did make them check it out as my repair was unrelated to the new problem. The shop guy admitted they had erred. I never went back to them!
Daniel
ediushu
Jul 17, 2013 09:55 AM
khscott2
May 17, 2009 06:50 PM
mr.mom
Apr 26, 2009 08:24 PM
jovance
Oct 2, 2006 04:33 PM
varmintjcl
Jun 23, 2005 09:37 PM
