2007 Sante Fe 2.7L AWD Humming noise
Old Feb 11, 2009 | 07:03 AM
samjackson's Avatar
Post 2007 Sante Fe 2.7L AWD Humming noise
I have been noticing a humming/vibration noise coming from my sante fe. I only makes the noise when the engine revs above 2,000 rpms and it does the noise again as the engine revs back down below 2,000 rpms. Usually when it revs back down below 2,000 rpms the noise seems to sound a little bit louder.
The noise is not a rattle sound, but more along the lines of a vibration/humming sound and only lasts for about a few seconds. A typically example of when the car makes the sound would be when I approach a stop sign. After I come to a stop and then accelerate, as the rpms go above 2,000 and then come back down under 2,000 I hear the noise. Any suggestions?
The weather has been on the cold side (live in the great lakes region). I look forward to hearing some feedback! Thanks,
Old Feb 11, 2009 | 07:40 AM
jsinton's Avatar
Banned
Do you change your own oil, or take it to Jiffy lube? The reason I ask is there is a technical service bulletin that talks about engine knock problems from using non-Hyundai oil filters. You might have this problem, as you say it's really cold, the oil is thick. Beyond that, I couldn't find any information.
Old Feb 18, 2009 | 01:18 PM
samjackson's Avatar
Thank you for the informative answer. I do not change my own oil, I take the walmart route - have the oil changed while i'm shopping at the super center.
OceanLvr812
Jun 3, 2019 07:49 PM
reman
Feb 2, 2011 05:04 PM
sayloc
Jan 24, 2009 07:06 PM
shiva
Sep 26, 2004 03:30 AM
