2009 Santa Fe V6 NEED HELP
2009 Santa Fe V6 has a loud noise coming from the back side of the engine block after cranking. It does not do it all the time. It sounds like a bad bearing screaming. The noise only happens when in park or neutral. If you put it in gear, the noise stops. If you put it back in neutral or park it starts again. Any thoughts or help would be greatly appreciated.
luvdodge
Feb 13, 2014 06:33 AM
