2014 Santa Fe will crank and run but won’t come out of park
I have a 2014 Santa Fe that has been perfect! Went to leave earlier and it wouldn’t come out of park. It cranks and everything works except for the dashboard and the ac blows hot instead of cold. It won’t shift into gear when mashing the brakes. But we can shift it using the shift lock release. The ABS light is on, check engine light, and the emergency brake light is on. All fuses are good. What could this be??
https://cimg4.ibsrv.net/gimg/www.hyu...fd4fd6ab1.jpeg https://cimg7.ibsrv.net/gimg/www.hyu...88c383df7.jpeg |
I guess there is a short in the wiring somewhere.
Is it still under warranty?
If yes then have dealer fix it If not then check all fusible links and fuses |
