2021 Santa Fe Electrical Question
My wife was deciding to do some electrical work for a bunch of accessories, and cut / mangled a bunch of wiring in the driver side junction block. Specifically ICU-F, ICU-G and another I cant identify yet from the wiring diagrams. I think I will need to re-pin these connectors, because I would rather avoid having to buy another wiring harness. Anyone have an idea where I could buy these pins and what size? Its the female side and they appear to be like 1.55 -> 1.59 mm on the end. I tried soldering / shrink wrap a few of the wires, but some of them are way too close to the connector, dont think I can fix them. Tons of CAN bus errors now. I think it is both p-can and b-can that are messed up. Additionally she accidentally cut and connected one of the wires from the floor board connector into the can. Haven't been able to figure out which one it is on the wiring diagrams so not sure the voltage, hoping it wasnt a direct 12v to the can bus. She isnt clear on which one she connected where either.
https://cimg8.ibsrv.net/gimg/www.hyu...3fc189a0db.jpg |
I would start with a dealership parts dept..
You might also check, Delphi weather pack terminals Waytek Amazon does show a kit, There are special tools required to disassemble plugs and terminals and tools to correctly assemble the miniature terminals to small gauge wiring. Sometimes large size auto supply stores , NAPA, A1 Auto, Advance, will stock some of these. |
