Air intake hose
Old Oct 4, 2020 | 07:54 AM
Koos's Avatar
Default Air intake hose
Hi.
if felt a power dip din my 2007 santafe 2.2 crdi 4x4 auto
the last time i towed my caravan. more when i go up hill.
Now i found n huge leak in my air intake hose.
awating new hose.
Could that have been the problem
Old Oct 4, 2020 | 09:20 AM
jbwood5's Avatar
Had the same cracked/split hose on my 2004, 2.7. If the crack results in a leak, it will affect your drivability since some air is getting into the throttle body without going through the mass air flow sensor. These hoses are pretty cheap on E-Bay (after market, of course). I think I got one for under $20.
Old Oct 4, 2020 | 11:02 AM
Until you manage to get a replacement hose you might consider the following,
Place a piece of Aluminum foil over the hole and secure it in place with duct tape . It is a temporary measure , but will suffice until the correct hose is installed as long as no air can get into the leak..
Koos
Oct 9, 2020 02:38 PM
Koos
Oct 5, 2020 05:18 PM
kuan720
Oct 6, 2018 11:39 PM
ElantraMan
Apr 22, 2010 10:20 AM
sr owna
Aug 7, 2009 06:51 AM
