Bizarre electrical problem, please help!
My 2001 Santa Fe is experiencing some strange electrical issues; my interior electrical systems seem to be failing one by one.
First, my remote keyless entry stopped working (despite the remotes both having brand new batteries. Then, my clock stopped working, either with the car on or with the key in the ACC position. Then, my dome light stopped working on "door" mode with the key in the ACC position, but if the car is started, it works just fine. However, with the key in the ACC position, the dome light works in the "on" position, just not the "door" position. Then, my car stereo stopped working. Then, my dash lights began to dim, even with them turned all the way up. My dash is barely readable now at night. My turn signals do not work anymore. My headlights will not work unless the car is turned on (they will not work with the key in the ACC position). My battery tests fine, and I've checked every fuse in my car both under the hood and the interior fuse box. No alternator lights have appeared, and my car runs fine with the negative battery terminal disconnected. Does anyone have any suggestions? |
RE: Bizarre electrical problem, please help!
Update: After looking around, I discovered that there's an open wire harness underneath the driver's seat. About a month ago, my car was broken into, and my radio taken. Is there supposed to be something underneath the seat? An amp or crossover maybe? If it was taken, could that be the cause of my electrical problems?
First, my remote keyless entry stopped working (despite the remotes both having brand new batteries. Then, my clock stopped working, either with the car on or with the key in the ACC position. Then, my dome light stopped working on "door" mode with the key in the ACC position, but if the car is started, it works just fine. However, with the key in the ACC position, the dome light works in the "on" position, just not the "door" position. Then, my car stereo stopped working. Then, my dash lights began to dim, even with them turned all the way up. My dash is barely readable now at night. My turn signals do not work anymore. My headlights will not work unless the car is turned on (they will not work with the key in the ACC position). Is there supposed to be something underneath the seat? About a month ago, my car was broken into, and my radio taken. No alternator lights have appeared, and my car runs fine with the negative battery terminal disconnected. |
Thanks for the help Ken.
It turns out that when I wrote "I checked every fuse in my car", I seemed to overlook a couple, including a blown fuse labeled clock (in the interior fuse box). I replaced that 10 amp fuse, and everything worked! Hyundai should relabel that fuse the "clock/dash light/dome light/radio/remote keyless entry" fuse. Am I the only one who finds it absurd that one fuse controls all of these systems? At any rate, all is well. Thanks again homie! By the way, I called the dealer, and they told me that the wiring harness underneath my seat is an airbag diagnostic port. Apparently, that's where the dealer installs their diagnostic equipment to examine airbag functionality...just so you know. |
Please help
I just purchased an 03 hyundai Santa Fe on Friday. Already I am having problems and the dealership basically tells me im on my own.:mad: The turn signals just stopped working on my way to work this morning. I cant figure out why. Is there a fuse or is there a more serious problem?
There's a turn signal relay. You can check the fuses too.
Do you know where the turn signal relay is?? :confused: So far today, I have been through 5 fuses. I purchased the car used, and I've only had it since Friday and already this is the 6th problem I'm having with the car. Thank you for your help on this.
You've been through five fuses? Please explain...
Turn signal relay should be in the fuse box under the hood.
