Brake light/ blinker problem.
Ok heres the deal. My right turn signal works fine unless the brake is pressed. The left works fine no problems. If the flashers are on and i press the brake the flashers stop on both sides. The brake lights work fine on both sides. Ive checked all the bulbs on both sides and everything is working fine. Its only a problem when im trying to use my right turn signal when the brake pedal is pressed the turn signal stops flashing and just lights up.
If anyone has had this same issue or might know what it would be itd be a huge help. I was thinking maybe the turn signal relay or maybe the brake switch...
I'm trying to answer your question and I was looking for more information because your posts were unclear. If you don't like it you can look elsewhere for your answer. Lose the attitude.
IcantDo55
Feb 16, 2014 06:37 PM
CLaabs
Oct 6, 2010 07:31 AM
