car having problem accelerating. Need a few tips..
Old May 6, 2011 | 10:40 PM
shockwhore's Avatar
Default car having problem accelerating. Need a few tips..
(2003 Hyundai Santa Fe 2.7L 4WD 166K miles) Car having a hard time accelerating. It will move all right, but very slowly esp. uphill. arrg. RPM increases very slowly. So far, I've checked:
1. Sparks Plugs (Replaced). Old ones looks slightly white, so running lean?
2. air filter. Looks good
3. Tranny fluid. Looks good and red
4. spark plug wires/coil or whatever you call it. Looks good. no cracks
5. Fresh gasoline. Added fuel injector cleaners and such
6. Mass air flow sensor. Looks good.
I'm going to check:
1. Fuel pump
2. fuel filter
3. fuel injectors (not sure how i would determine if injectors are clogged)
4. catalytic converter/muffler and muffler pipe (could be clogged?)
Anything else to check for? I'm thinking it's got something to do with the fuel delivery since my plugs look a bit white. No error codes when I checked. idle is normal like always.
I really hope it's not the torque converter... arrrggg.. $700+ to replace.
Old May 8, 2011 | 04:10 PM
shockwhore's Avatar
checked fuel pressure and it was around 47psi which seems normal. With engine running, the pressure dropped about 7-10 psi which also seems normal. Unplugged hose connected to pressure regulator and pressure went back up to 47psi which is normal? i think it is suppose to do this. Someone correct me.
-Fuel pump is still good, but what about when at higher RPM? Fuel pump may not provide enough pressure. Need to hook up a fuel pressure gauge pod to check this.
- Still have to check fuel filter.
- Still have to check the cat converters.
arrrgggg..
odysseymsc
Mar 26, 2015 07:18 PM
accenttheaccent24
Feb 18, 2009 07:24 AM
merbenz84
Aug 30, 2008 08:07 PM
arliss7
May 8, 2008 09:46 AM
Memento
Jun 16, 2006 03:37 PM
