-   -   DBC, ABS and ESC dashlights will not go out (https://www.hyundaiforum.com/forum/hyundai-santa-fe-20/dbc-abs-esc-dashlights-will-not-go-out-14669/)
Sandrews58 Oct 13, 2014 10:51 AM
I have a 2012 Santa Fe Limited with about 53,000 miles. I have been experiencing a off and on issue with a group of dashboard lights.
The ABS, ESC and DBC lights turn on at startup and do not go out, the DBC light goes from yellow to red in color the other two stay yellow.
The dash switch buttons for the BDC and ESC do not respond when pushed in.
Sometimes the three lights will turn off on there own when the car is turned off and restarted, but this is after a couple of days.
When the lights are no longer on the control buttons on the dash work properly.
I can use some help to try and figure out the issue. My thought is maybe a dodgy sensor or electrical issue of some kind.
Thanks,
Steve
NovaResource Oct 13, 2014 04:27 PM
Maybe this: https://www.hyundaiforum.com/forum/g...e-lights-6251/
Brake lamp switch
Sandrews58 Oct 14, 2014 12:41 PM
UPdate
I went to the dealer and the issue was a bad sensor in the passenger rear wheel hub. Seems the sensor was not counting the wheel spin, so I was told.
Dealer fixed it under warranty.
NovaResource Oct 15, 2014 06:48 AM
Yes, a bad wheel speed sensor could cause that problem.
https://www.hyundaiforum.com/forum/h...-lights-14220/
https://www.hyundaiforum.com/forum/h...s-light-10764/
https://www.hyundaiforum.com/forum/h...engaged-12379/
https://www.hyundaiforum.com/forum/h...-lights-14246/
FabricGATOR Nov 21, 2016 09:26 AM
Can either of you guys advise what is involved with troubleshooting or replacing this right rear sensor on a 2010 front wheel 4 cylinder model? I get the code that it is not signaling the wheel speed. Cleaned / inspected the plug at wheel and wires.
What is involved in changing this? It appears to be under (behind) the wheel bearing hub. Is it one piece (bearing and sensor) or can just the sensor be changed? Expensive part? Any special tools required (other than an ABS brake scanner)(I borrow from a friend /snapon)
Thanks!
hanky Oct 30, 2021 07:57 AM
We all wish our cars would be trouble free, ALL THE TIME, but it just ain't so.
Considering your vehicle is a 2010 year model, it has had many chances to acquire some problems if nothing else , due to time and exposure.
Just what kind of warranty you might have received is dependent on the seller.
Intermittent problems can be quite trying to find, and prove they were corrected even more trying because you can't get them to show up to verify that might have been the source of the problem. This will take some patience and time to locate and hopefully the problem can be corrected to your satisfaction.
