doors closing, windows down, noise
Old Dec 19, 2009 | 03:49 PM
cdoo's Avatar
Default doors closing, windows down, noise
I know on this forum and others, the issue with the windows being down while driving has been posted before. It plays a number on the ears and is somewhat unbearable. I haven't seen an explanation for it, so I'd like to propose the potential problem, it may even explain other noises. I thought about this while I was closing doors the other day while cleaning the Santa Fe.
If I close one door, it doesn't matter which, there is a noise in the right rear, a rattle, or like something is loose. I've checked under the wheel well, in the rear, all over and I can't find the source. If other doors or windows are open, I don't hear the noise when closing a door. Because of this, I assume its cabin pressure/compression being increased when closing the door.
Thinking about it, I visualize a one way valve to equalize cabin pressure when a door is being shut. It would also explain the issue of driving with the windows down. When driving with the windows down, cabin pressure increases as the fast moving air out side compresses inside the car. That would trigger a one way valve to equalize pressure. But it would do it over and over again causing the "whump whump whump" inside the car.
Does anyone have knowledge of this type of mechanism on this car or others?
Old Jan 5, 2010 | 05:41 PM
Mooch's Avatar
the problem and the noise comes frome the damper i have the same problem...if you change the damper's for example with monroe the noise will be gone......a friend of mine did it!!!!!!!!
Jack Seeders
Apr 20, 2013 08:03 PM
varieurry
Oct 14, 2011 03:11 PM
millersmm76
Feb 28, 2008 10:35 AM
wjc77
Feb 13, 2006 12:17 AM
laine1998
Dec 29, 2004 01:18 PM
