Engine Work - Serpentine / Timing
Hello everyone, I am attempting to service a 2.7L 2005 Hyundai Santa Fe for a friend.
ISSUE: Serpentine Belt - Belt Frayed - Belt slipped off tensioner nearest A/C Compressor / Upper Motor Mount - Belt tore into and is stuck inside timing belt cover and possibly a gear or tensioner that lies behind the cover, beneath the upper motor mount. - Belt stuck behind drive pulley on crankshaft. Serpentine Belt Tensioner - Serpentine Tensioner melted nearest A/C Compressor / Upper Motor Mount Timing Belt - ??? Initial inspection looks good, but I'm no expert. (Viewed from top with Cam Gear timing belt cover removed.) Cam Gears - Alignment between gears okay (Both dots align with both indentation in the valve cover.) - Cam / Crank alignment (I saw a T mark on the tab overhanging the crank pulley but the crank pulley mark is not aligned perfectly with the T mark. My experience with other engines tells me that a slightly off is okay, and I've done it to Honda motors to tune cam timing, but I would like confirmation for this particular motor.) UPDATE: (12/05/2009) Requested Information: RECEIVED (12/05/2009) Crank Rotation Received Requested Information, Information is as follows: Crank Rotation = Clockwise UPDATE: Serpentine Belt Removed. Rotated crank counter clockwise to help unwedge belt from drive pulley. Re-Routed belt out crank bolt access hole by front tire to get a pulling angle and removed the portion that was wedged in by the upper motor mount. Specific Information For: 2005 2.7L V6 Motor Auto Tensioner needs to be loosened or removed to service serpentine belt Auto tensioner Receives a 3/8" drive Auto Tensioner rotates down/clockwise |
5 Attachment(s)
Chalk is cheap, Pictures are worth a thousand words.
Chalk used to marking Belt and Valve cover. Attachment 1845 http://i23.photobucket.com/albums/b3...l/IMG_3256.jpg Attachment 1846 Damaged Timing Belt Cover Attachment 1847 Close Up Attachment 1848 Damaged Belt and Belt Tensioner Attachment 1849 Well I hope these picture are general enough for others to use as reference and specific enough to show the issue at hand. |
New serpentine belt is on as well as the new tensioner, I call it a tensioner because it keeps tension in the belt even though the real tension is from the Auto Tensioner. I swung the timing belt around again... this time the "T" (0 degrees) hit dead on so I probably just turned the crank too far the first time.
Car runs great, my initial fears that the timing belt might have slipped a tooth were cleared. Once the final pics are up I can compile a more complete how to and post it up for the mods to do with what they will. Since the old belt was in shambles and off the auto tensioner I had no real clue of the belt routing. Chilton's, while I can respect what they do is useless when it comes to "DETAILED" documentations. The book itself was pretty darn thin so that should have given me an good indication of the level of detail. I will try and post pics when I get a camera. Mostly a pic of the hole in the "Auto Tensioner" for the breaker bar, really though a breaker bar is inappropriate because of it's length. A socket wrench coupled with a combination spanner/wrench place near the end of the socket wrench handle will in effect give you a "L" shaped handle that offers both leverage and a much broader range of motion. I'll post pics of the belt routing or make a 3D model of it for reference. I shall also post pics of the "L" since I mentioned it. |
Originally Posted by Espera
(Post 25646)
