Extremely warm inside vehicle
Old May 21, 2020 | 02:26 PM
Bstewart's Avatar
Default Extremely warm inside vehicle
Hello,
I have a 2004 Santa Fe 2.7 V6. I've had it two years and it was taken care of well prior to my purchase. The issue I'm having is that, it seems to be running very hot. I know engine's get warm but, it seems a bit more than normal. I can feel heat coming through the vents on top of the dash. I can also feel it coming through the center vent. Could this be a barrier between the engine and dash that's worn out?. I've had an oil change, trans flush, along with new wires and plugs. I've also had the codes read and nothing comes back as to why I'm feeling all this heat. Thermostat is good, my temp gauge sits a little under the half mark and my radiator is good. I cant seem to figure out why it seems to be running hot but, it's not, if that makes sense. I appreciate any suggestions.
Thanks,
Bstewart
Old May 21, 2020 | 05:46 PM
avisitor's Avatar
Look at the climate controls and see if the set temperature is set to warm or hot.
Old May 21, 2020 | 09:03 PM
Bstewart's Avatar
Default Thanks avisitor
I actually have the temperature control all the on cool. That would have been too much like right though, huh?. Lol
Old May 22, 2020 | 11:03 AM
avisitor's Avatar
Do you have the air vents open? Maybe it is letting heat from the engine into the passenger compartment?
Heat shield is usually inside of the passenger compartment.
It doesn't fall out or wear out.
Feeling it in the vents ??
uemaco
Sep 21, 2013 10:29 AM
rickalty
Apr 13, 2010 03:31 PM
fluffypinkkittey
Feb 11, 2008 07:49 PM
crhorsley
Jan 18, 2007 05:40 PM
whiteorean84
Feb 7, 2006 04:36 PM
