power steering whining and foaming
I have a 2003 Hyundia Santa Fe, everything is fine when I first start the car, but after driving for about 20 min. and the engine is warmed up I start to hear the power steering whine. It whines as I go straight and then gets even louder when I turn the wheel. After I turn off the car I went to look and there is foam in the power steering reservoir. After the foam goes away and engine cools the whining goes away when I restart the car. Can anyone help me with this I am stumbled. I put regular power steering fluid but the manual calls for PSF-3, not sure if there is a difference?
First, stop making multiple thread with the exact same post.
Second, you can add PSF-4 to a PSF-3 system but not the reverse. I don't know what you used in your Santa Fe but I would drain the system and refill with all PSF-4.
I usually drain the system by disconnecting the return line (the low pressure line from the rack to the pump reservoir), putting it and pan and plugging the return port on the pump. Then with the engine running, steer the wheels left and right to pump out all the fluid while slowly pouring in new fluid. Once all the old fluid is out, reconnect the return line and refill all the way.
