Santa Fe 2003 2.7 front engine mount replacement
Old Jan 11, 2012 | 06:56 AM
gary_c's Avatar
Default Santa Fe 2003 2.7 front engine mount replacement
Any tips on how to get the mount out after supporting the front of the engine? Does the whole mount bracket attached to the engine need removed or can you just remove the rubber mount piece attached to the front frame out?
Thanks
Old Jan 11, 2012 | 05:49 PM
gary_c's Avatar
I figured it out. If you take out the bottom bolt on the engine bracket and loosen the top bolt you can rotate the engine bracket just enough to slide the rubber mount pass the crossbar.
stu999
Jul 2, 2011 12:37 AM
baja
Mar 14, 2010 09:54 PM
Accentcrazy
Oct 10, 2007 09:53 PM
Chris0628
Oct 31, 2006 01:18 AM
toolazyforalogin
Feb 15, 2006 11:59 PM
