Santa Fe Air Conditioning Operation
I have an '06 Santa Fe with the 2.7 L motor. The air conditioner is cycling
on and off and at times not cooling. The pressure of the gas is roughly 150 psi at 110 degrees F ambient, temperature of metal tube measured near high pressure port. I believe that to be a normal pressure for R-134A. Operational pressures at high and low ports are roughly 325 and 35 psi respecfully at idle speed. I have looked at the Hyundai website and gotten bits and pieces of the system operation, triple pressure switch w/pressure values in kg/cm2. Not real sure where the pressure switch is located. I would like to know if anyone has knowledge of a reference that will show the system components' locations under the hood and if some sort of theory of operation might exist that I could study to see if I actually have a concern. Should a normally serviced system cycle on and off in four to eight second time intervals? Does this indicate and overcharged system or perhaps a triple presure switch problem? Just a few questions, I think the issue should be simple as the system is operational, just seems to poop out when it gets hot outside. Thank you in advance |
The Rest of the Story (No Whining)
I bought the vehicle in June 2010, summer heat caused the A/C to drop
off once or twice, didn't tell mama. This summer, last week, mama took the car with her girl friends to lunch, temps above 100 F. Well, the car decided not to cool, uh-oh. My previous rant was one of frustration with the product line, little or no experience. Went to the library and checked out the FSM # A26S-EU36D, Volumes I and II as well as a Chilton's, now Haynes book, P/N 32200 for the 2001 through 2006 Santa Fe's, the FSM was for an '04, since mine is an '06 and same design series, assumed that manual would work for my issues. The FSM tells me that I can operate the car with the hight port pressure between 199 and 228 PSI. Measured the pressure at 375 PSI and thought this might explain the shut off issues, sure enough the triple pressure switch I was asking about was most likely the issue of shut off. Bled the pressure in increments to see just how far I could take her and still get cooling that I wanted. Wound up with a high port pressure of 255 PSI and low port of 35 PSI to get the cooling I wanted inside the cabin. She pushes 42 degree F air with outside temps at 98 F. I found that if I took the pressure much below the 255 mark, she just didn't want to cool right. I know the FSM says high port pressures should not exceed 228, but mine just doesn't want to cool at that pressure. I am not one to go and invest a couple of grand to make it perform to spec when I can operate her at pressures up to 375 PSI and not blow... So, my 255 PSI high port pressure will be what I go with. Remember to watch your ambient temps, they will force your pressures up. Actually, the pressures I am seeing now are totally in line with the gage manufacturer's charts, just don't line up with the Korean FSM data. Oh, the triple pressure switch appears to be mounted on top of the RH fender in line with the high pressure line, roughly 18 inches aft of the pressure port. You Guru's that read this, know that I just want to share some life experience here and am aware that I probably need to replace the system, just don't want to take it to the dealer and exchange a pound of flesh for the work. Might consider giving my first born though..... Hope this lesson informs someone on the forum. Oh, mama took the car 20 minutes ago in 103 degree heat, my phone has not rung and yes it is turned on..... Happy 4th of July to all. Tried to upload schematic diagram, not able to do so. If you would like an E-Mail with a gif or pdf of the schematic from the FSM drop me a line at millweigh@yahoo.com and I will attach the file to my reply. Cheers. |
| All times are GMT -5. The time now is 03:04 AM. |
